94' stalling problem
Old Feb 4, 2005 | 01:09 PM
Wylieford05's Avatar
Wylieford05
Exclamation 94' stalling problem
my 94' f150 w/ 351wdrives fine, but when i come to say a stop sign, it revs, the whole truck actually rocks foward, the battery meter goes down, and it almost dies (sometimes it has). if i put it into neutral it stops, only does it in drive or reverse. Any ideas what would cause this?
Old Feb 4, 2005 | 03:33 PM
jtmerritt's Avatar
jtmerritt
Sounds like it may be a case of the locked up torque converter not releasing right away which results in effect to not pushing in the clutch on a stick soon enough. Check all connections at the tranny to make sure they are clean and tight and are not corroded. Could also be the torque conveter lock up solenoid not working properly.
John
