Anyone have trouble with parking brake?
Old 02-03-2005, 05:20 AM
95250mac's Avatar
95250mac
95250mac is offline
Does anyone have issues with the parking brake not holding the truck on F250's with disk brakes in the rear?
Old 02-03-2005, 05:48 AM
SRD4X4's Avatar
SRD4X4
SRD4X4 is offline
Have you checked the linings ? ( thickness/adjustment )
Old 02-05-2005, 05:03 PM
peppy's Avatar
peppy
peppy is offline
If the brake cable is rusted, likely the cable is rusted inside, therefore sticking.
Exactly my problem right now with the parkiong brake.
Old 02-06-2005, 09:38 AM
low's Avatar
low
low is offline
They could either be out of adjustment, in which case you can crawl underneath and remove the rubber plug and adjust them up, or you may have rear hub seals leaking on them, making them slip. This is a common problem. If you see any oil on your inside rear tire or smell rear end oil around there, that's prolly the problem.
makthenif
1997 - 2003 F150
12-27-2015 10:01 AM
300sflyer
1999 to 2016 Super Duty
11-07-2014 10:29 PM
coreyw2
Large Truck
09-25-2014 07:04 PM
thewojoes
08-03-2013 09:16 AM
tbean
05-09-2013 01:31 PM
Quick Reply: Anyone have trouble with parking brake?
