Sponsored by: Real Truck
Skyjacker leveling system installed
Old Jan 10, 2005 | 10:07 AM
GloNDark's Avatar
GloNDark
I got the skyjacker add a leaf system and track bar relocation bracket for Christmas. Put it on the following day.
Installation? Easy, took about an hour and half total. Only problem I ran into was the new center pin bolts were way to long, but 20 seconds with the cut off wheel and that was solved.
Is it level? not quite, but it did raise it nearly 3 inches. The back still sits about 1.5" higher which is perfect for me.
Specs
1999 F250
V10
315-75r16 on stock XLT wheels.
Old Jan 10, 2005 | 11:42 AM
madjak's Avatar
madjak
Looks great! Did you have to adjust headlights?
Old Jan 10, 2005 | 12:17 PM
GloNDark's Avatar
GloNDark
Good question!! Yes I did. However I found before that I could never get enough light "UP" on the road without the headlights looking like they were way tweaked out of shape. But now, they still flow with the rest of the lights, contour wise, but put plently of light on the road.
Old Jan 10, 2005 | 12:51 PM
Autobahn F-250 Lariat's Avatar
Lookin good
Old Jan 10, 2005 | 12:58 PM
richtor's Avatar
richtor
Thumbs up
the truck looks great. like you i like a small rake so when im hauling or towing something the truck will not be high in the front. i just have one question. when people buy the leveling kits do they expect them their trucks to be absolutely level? do these people actually like the look when the front is above the back when the truck is working?
once again nice looking truck. the 1.5 inch rake will look good at play and at work.
Old Jan 10, 2005 | 01:27 PM
beemr's Avatar
beemr
What brand tires are you running, and how are they wearing on the stock rims? How many miles do they have?
Old Jan 10, 2005 | 02:19 PM
GloNDark's Avatar
GloNDark
I love the rake, I can't stand trucks that are higher in the front than the rear. Hell I even put air bags on the rear, just in case.
As far as tires. Those are 315 &5 R 16 BFG AT KO's (Whew that's a mouthful) I have probably 1500 miles on them so far. Front Pressure is at 42 PSI and the rear is at 40 PSI. I played with that a bit to get them to wear evenly across the tread pattern. I took a piece of chalk, and drew a heavy line across the tires and drove around the block. Once I got the chalk to wear evenly across the tread, I left it. Love the tires, and eventually will go with different rims. Only because the offset is a little deep, they will rub the leaf a little bit at full lock.
Old Jan 11, 2005 | 03:24 PM
JMACC's Avatar
JMACC
Is that low pressure for that size tire? I have the 265 75R/16 and max pressure is 65psi cold I run them between 55 and 60 and have had no problems. But love the 315's nice truck.
JMACC
Old Jan 11, 2005 | 04:27 PM
beemr's Avatar
beemr
That size tire is a little big (wide) for the stock rims. He adjusted the air pressure so as to achieve even tread wear across the total tire width. If he aired them up higher, then the middle of the tire would wear prematurely.
Old Jan 11, 2005 | 10:28 PM
Hockycop's Avatar
Hockycop
GloNdark
That really looks good, A little off topic, Where did you get the clear parking lences? Are they from a 2002? I take it those are 1999 stock head lights. I like the look...
Thanks Bob
Old Jan 12, 2005 | 09:46 AM
GloNDark's Avatar
GloNDark
Originally Posted by Hockycop
GloNdark
Thanks Bob
I got those off ebay. Paid like $28 plus shipping on them. Search for "99-00-04 F-250 F-350 EXCURSION EURO CLEAR CORNER LIGHTS" and you should find em.
As for the headlights, yup, stock 99 headlights. I was going to replace them, but after polishing them up with the buffer and some rubbing then polishing compound they cleaned up nicely.
Old Jan 12, 2005 | 11:43 PM
Yota-eater's Avatar
Yota-eater
I just got the same kit. But mine is better Chris, you'll have to come over and help to supervise the install. I'll post up some pics also.
Geoff
Brown Falcon
Oregon Chapter
Dec 29, 2011 11:02 PM
harrisford
User Gallery & Picture Display
Jul 16, 2011 08:09 PM
wb6anp
S. California Chapter
Sep 13, 2009 03:14 PM
byro01
Jun 24, 2009 09:12 AM
AF Mezkin
Jan 12, 2006 12:41 PM
