Sponsored by: Auxito
Decent affordable code scanner
Old Jan 5, 2005 | 05:35 PM
tvvbsn's Avatar
tvvbsn
I am looking for a functional code scanner that doesn't cost me a lot of money. I would like to spend less than 200 bucks. I want to be able to read why my check engine light is on and be able to turn the light off. I was looking at an Actron CP9135 and thought that that was a pretty good option. I have a Palm and wouldn't mind using that either if I could find a good program and cables for around 200 bucks either. I am leaning towards a selfcontained unit though. I was just wondering if anyone had any experience with this unit or any other in this price range.
Thanks
Tim
Old Jan 5, 2005 | 07:17 PM
Racerguy's Avatar
Racerguy
Probably any cheap scan tool will read your codes and clear the light.
If you get something like at http://www.autotap.com/products.html you'll also be able to watch sensors in real time, view freeze frame data etc if any of that is important to you.
A better scan tool may be able to also read ABS, airbag GEM codes etc.
Old Jan 5, 2005 | 09:02 PM
CJK440's Avatar
CJK440
Actron also makes a cheaper one for about $70 that gives off the code itself instead of the the code + description. You have to look the code up in a book.
Old Jan 5, 2005 | 11:26 PM
tvvbsn's Avatar
tvvbsn
The biggest thing that I will be using it for right away is to figure out which cylinder is misfiring so I can replace the bad coils instead of all of them at once.
