Check engine light code
Old Dec 21, 2004 | 06:41 PM
DANA60's Avatar
DANA60
Question Check engine light code
I have a 1996 F-150 4x4 5spd 302. The check engine light has been on for about 2 weeks and it went off once but came on and is still on. I pulled the codes and code 133 (O2 sensor circuit slow response (bank 1 sensor 1). Does this mean i need to replace one of the O2 sensors and if so which one. Any responses are appreciated. Thanks
Old Dec 21, 2004 | 08:10 PM
fefarms's Avatar
fefarms
The sensors would be the ones closest to the engine (ahead of the catalyst). It isn't possible for sensors after the catalyst to get such a code (they will always be "slow" with a working catalyst due to the action of the catalyst). Code P0420 comes when the post catalyst sensor has a response similar to the pre-catalyst sensor.
I'm not sure whether bank 1 is the left side or the right side on a Ford. Personally, I'd change out the pre-catalyst sensors on both sides. They likely have similar amounts of age on them. Expected sensor lifetime is around 60000 miles, though they often go longer. A slow sensor will tend to degrade your gas mileage.
Old Dec 21, 2004 | 08:14 PM
DANA60's Avatar
DANA60
Thanks for the reply i think i'll replace both the O2 sensors
