Grinding noise in brakes?
I have a problem with my 98 Explorer Sport (4x4, SOHC) that I'm hoping someone might be familiar with. When I begin to slow down, I hear an awful grinding noise in the front end (not sure if it's coming from the rear also).
Here's what happened... a friend just did some work on the front end for me. Replaced the brake pads, shocks, lower ball joints, outer tie rod ends and the driver's side rotor. Took it to a Firestone shop for an alignment the next day. The first time I drove it was when I picked it up from having the alignment done. It sounds terrible! The brakes work, but are grinding. It doesn't sound/feel right when I'm not using the brakes either (but it's not as loud). His explanation is that there's rust on the rotor from non-use (which he says is normal) and it should subside after the rust is worn off. I think something else is wrong.
First question -- does anyone have any suggestions of what the problem might be?
Also, my ABS light is now on and when I asked about it, he said he broke one of the sensors. Second question -- does anyone know if it's possible to buy the sensor by itself (perhaps from a junk yard)? Seems kind of ridiculous to replace the whole hub assembly just for that damn sensor.
Thanks,
Sandy
Thanks,
Sandy
If the Pads are Installed incorrectly it will make the Grinding Sound. Also if the true cause is Rust, this rust should be visible on the brake rotor without even taking the tire off the car. If it makes noise all the time while driving, it could be a berring, but an impropperly installed Pad will also cause this problem. Have someone a little more qualified look at your wheels. Auto Zone does Carry the Sensor for the Hub for $83.00, and a New Hub w/ Sensor for $175, I am guessing you will want to find a used one though.
David
David
grinding noise
hello, i was wondering if u knew what type of brakes he installed , cause cheap brake pads also have a tendency to make this grinding noise.i have this exact same explorer yr.& model, i replaced the brakes about a year ago with Raybestos heavyduty brake pads& at first i had the grinding noise for about a week till they wore in, rotors were cut to,& they also were very rusty.the sensor not sure about but do you have this grinding noise when your about to stop or when you take off?
