Crankcase foam or condensation or what?
Old 12-08-2004, 04:03 PM
Ford Louisville's Avatar
Ford Louisville
Ford Louisville is offline
I've had my '98 F150 since early Y2K and have noticed a light brown oil at the filler port ever since owning it. The truck had 28,000 miles on it when bought and now is around 121,000. Today, while replacing 2 tires I had the oil changed and was watching it drain out. No stirations in the used oil. The mechanic lowered the truck down to fill the crankcase and pointed the light brown oil out to me, I told him it's always been that way. He said I may want to do a compression check and I told him these '98 engines have a history of failed gaskets. The engine idles smooth and I'm not beyond pushing it when traffic is light. It runs fine. What do you Blue Oval loyals think?
Old 12-08-2004, 09:09 PM
BrianA's Avatar
BrianA
BrianA is offline
If it is what I am imagining, mine has the same thin film of oil on the bottom of the fill port cap. It has always had the oil film.
At 150,000 I'm guessing it's not anything to worry about.
Old 12-12-2004, 04:11 PM
Ford Louisville
Thanks Brian. It runs really good and like yours, it's always been there. I ain't losing no sleep over it.
Old 12-29-2004, 07:45 AM
redneckfarmer's Avatar
redneckfarmer
redneckfarmer is offline
if it was a blowed head gasket the oil cap would probably have white foam on it. and if you put all of those miles on it i dont think you have to worry about it being a blown head gasket.
later
Trap2
1999 to 2016 Super Duty
01-18-2019 11:18 PM
Dewdzilla
1997 - 2003 F150
07-15-2013 04:52 PM
95ford250_460
01-11-2005 03:35 AM
Steve Butabi
11-15-2004 05:54 PM
nissanjon
07-29-1999 10:52 PM
Quick Reply: Crankcase foam or condensation or what?
