Need Vin #'s De-coded
Old Dec 6, 2004 | 11:19 AM
engineguy33's Avatar
engineguy33
Talking Need Vin #'s De-coded
hi there
I got the vin number for the 69 f250 crew 4x4 and would like to know all you guys can find but especially if the year is right according to the serial number, well the vin # is F26YCE27262. any help is apperciated
also I have a 1968 f250 crew 2 wheel I took all the numbers of the tag and here they are
F25YCD17094
WB Model BODY Trans
149 F254 3 81 A B4
06900 179 4000 440322
GVW cert hp RPM DSO
Also if any of you guys have a guess at what they might be worth, the 4x4 is good body with decent motor buy the interior is a mess with a hack job to it and the 4x2 is in good shape with only a little rust on the box
I appreciate any help I can get as I'm new to these crew cabs but been a ford lover for awhile
thanks
Aaron
Old Dec 6, 2004 | 02:56 PM
SFC DAVIS's Avatar
SFC DAVIS
1969 F250
F26= F250 4wd
Y= 360ci V-8
C= Made in Ontario, CAN
E27262= consecutive build number projected for Nov 1968 (69 model year)
1968 F250
F25= F250 2wd
Y= 360ci V-8
Y= Made in Ontario, CAN
D117904= Consecutive build number projected for Apr 1968 (68 model year)
149= Wheelbase in inches
F254= 6900GVW
3= Interior Medium Beige
81=Conventional Cab
A= 4 Speed New Process Transmission (NP435)
B4= Rear Axle gear 4.10 Dana 60
06900= GVW
179=Horsepower
4000= RPM necessary for 179 horsepower
DSO 440322= 44 for Twin Cities, have no idea what 0322 is for.
Hope this helps.
Old Dec 6, 2004 | 08:26 PM
engineguy33
Talking thank you
well that's just what I wanted to know I guess I'll get after it the 4x4 it needs alot of work on the interrior but the body in in good shape thanks again
Aaron
