1978 - 1996 Big Bronco
Quick ignition switch question
Old Dec 5, 2004 | 02:34 PM
MatthewC's Avatar
MatthewC
Radio has stopped working. Tested the key power wire with the key turned, but no power in any position. I am assuming that the ignition switch has a burned out portion. Would I be correct? Fuses are fine, battery power to radio is fine.
-Matt
Old Dec 5, 2004 | 02:58 PM
skelator's Avatar
skelator
sounds like a good guess to me, check the harness that connects the steering column to everything else and see if all of the wires there are getting power.
