51 6 cylinder Flathead Oil Pres Question
Old 01-20-2005, 09:35 PM
51ford fan's Avatar
51ford fan
51ford fan is offline
Ok all you 226 7HA Flathead guys what kind of oil pressure is your gauge holding. When engine is warmed up I'm getting 20 psi at idle and 55 psi above idle.
Old 01-21-2005, 10:20 PM
jboren's Avatar
jboren
jboren is offline
I think the pressure relief should be set at 57 so it looks right to me. If those are "hot" figures then I believe that is real good. I don't have a mechanical gauge on mine but the stock electric gauge reads close to those same numbers and I know my engine is very tired! I don't think I have ever seen a bottom end that is any more overbuilt than the 226-H. That is a tough little motor.
Old 01-25-2005, 11:05 AM
Lazy Hog Farmer's Avatar
Lazy Hog Farmer
Lazy Hog Farmer is offline
51, you can be very happy with your oil pressure. I have a freshly rebuilt 59A that has good start up pressure (50 lbs.) . At prolonged idle it drops to 7 psi. I know a knowledgable ex flathead racer and he says that if you have any kind of pressure at all at idle (5-10 lbs.) it is adequate. He,s given me much valuable info over the last few years and has not steered me wrong yet. Steve
Old 01-25-2005, 12:22 PM
SteV8e's Avatar
SteV8e
SteV8e is offline
Anything more than 50 psi is a waste; it takes horsepower to pump oil to pressure. I concur that 5 psi at idle is adequate for a warm engine.
Old 01-25-2005, 08:27 PM
51ford fan's Avatar
51ford fan
Thanks guys for the input.
51dueller
Flathead V8 & Flathead 6
26
11-13-2016 07:43 PM
Tienmac
08-25-2016 09:02 AM
randycarmichael
11-11-2015 12:01 PM
rustyrelic
44
04-29-2015 07:24 AM
51f-1fan
11-05-2006 09:46 AM
Quick Reply: 51 6 cylinder Flathead Oil Pres Question
