BFG or Nitto 35s with leveling kit only?
I'm strongly considering going with BFG AT 315/70/17 tires with a 2.5'' Daystar kit. Anyone out there running BFG or Nitto 35's with the Daystar kit, and if so, did you get any rub? I get conflicting answers on whether or not that set up will work. If you have that set up, I'd love to see pictures and hear about your experience. Thanks a bunch.
I was thinking the same thing. From what I have read, if you stay with stock wheels there is no rubbing. Aftermarket wheels that are wider and different backspacing are the problem. Dealers in the Little Rock area are putting on daystar lifts and running BFG 35x12.50x17 MT's or 18's on a regular basis. One dealer has on with a 6" lift and 37x12.50x18's on stock wheels. Information says these tires need to be on at least 8.5" wide wheels. Dealers don't care so it must be ok...
ij........that is good to know. I suspect going with 18x9 wheels won't make much of a difference than stock, it is up to the back spacing. The wheels I am looking at have a 5" backspace. I have searched the gallery and only seen stock wheels on the BFG 35s. If anyone has done some custom wheels with 35s, I'd sure like to see a picture.
I have Eagle Series 178 18x9 wheels with Nitto 325/65R18's and get a bit of rubbing when fully cranked. Before my Body Lift I ran 325/60R18's with just the daystar 2.5 and still had the rub. The Nitto's are 13" wide the BFG's are 12.50" wide. When the Nitto's wear out BFG's will be the next tires on Blkbuty. I may opt for the Open Country M/T from Toyo which are 12.5" wide as well.
Hovy: I have just alittle rub and the tire shop actually shaved off the areas for me while in the shop.
CA: I love the lift(s) and the Nitto's - going to TOYO or BFG for a more meatier look. The Nitto's ride great.
CARN: The 18" stock rims are 7.5" and MOST tires 33" 35" tires recommend 9" wheels BuTTTT! My buddy runs 33's on his stock Fx4 rims and it looks good!
