frame differences
Old Oct 21, 2004 | 02:16 PM
Drool Monkey's Avatar
Drool Monkey
frame differences
what are the differences between the frame of a 1955 and a 1953?? ...suspension parts?
Old Oct 21, 2004 | 02:22 PM
mt54's Avatar
mt54
I'm pretty sure there is no difference, in fact allmost possitive.
Mike
Old Oct 21, 2004 | 02:35 PM
Drool Monkey
in which case, suspensions parts are interchangeable ...correct?
Old Oct 21, 2004 | 02:37 PM
merc546's Avatar
merc546
The rear springs are 4 inches longer on the 55-56, which would relocate the rear spring mounts (I would think the rear crossmember is back 4 inches from the 53-54 also, but maybe not) other then that nothing.
Chuck
Old Oct 21, 2004 | 02:41 PM
mt54's Avatar
mt54
I'm thinking only the 56 for the rear spring difference. Yes I belive the parts will interchange. You could always check with a parts suplier, see if they list the same part # for both years for the parts you want to use
Mike
Old Oct 22, 2004 | 09:13 AM
Drool Monkey
is there a smoother ride with the longer springs? ...did ford move them for a good reason?
Old Oct 22, 2004 | 11:03 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Generally speaking the longer the springs are (assuming they have the same number of leaves) the smoother the ride is. The shorter stubby springs are more for weight bearing than for ride comfort.
Vern
