Keyless Entry Remote Replacement
Old Dec 27, 2002 | 08:48 AM
batch's Avatar
batch
Hello all,
I have a 95 SuperCab (4.0L with 123000 miles and it runs GREAT!)
The problem I am having is that both of my keyless entry remote have broken and I would like to replace them so I can put them back on my key ring.
So my plan is to just buy one off eBay. I have noticed that there are two kinds of remotes. The one for my truck, which is usually listed as 95-98 and the newer type with is usually listed as 98 and newer.
The older type has text printed on the buttons and the newer type uses icons. I have noticed that the newer type seems to be more durable (we had them on my wifes car) and I would like to purchase that type if I can.
Does anyone know if the newer type remotes will work on a 95?
Many thanks and have a great new year.
Old Dec 28, 2002 | 09:57 PM
TruckLarry's Avatar
TruckLarry
Old Dec 29, 2002 | 12:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check with the Ford dealer for the part numbers required. You will also have to code them to your truck. Most of these RF type devices are a matched set and sometimes a replacement will be non-functional or have reduced range.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 3, 2003 | 09:29 AM
cjdague's Avatar
cjdague
I was told that, if you hold down one of the buttons on the key fob and cycle the ignition on and off, this will reset the codes.
Old Jan 3, 2003 | 09:59 AM
garymake's Avatar
garymake
[updated:LAST EDITED ON 03-Jan-03 AT 11:01 AM (EST)]I reprogrammed my remotes so that they work both my Superduty and my Ranger (I now have 4 remotes for the two trucks). I am listing the procedure that I followed to reprogram my trucks for the new remotes (I found this procedure in the owners manual for my 2002 F250. It worked for both my 2002 Ranger and my 2002 F250 - I don't know if it will work for your truck or not).
Instructions from the owners manual:
To program the transmitters it is necessary to have all (maximum of four — original and/or new) of your remote transmitters available prior to beginning this procedure.
To program the transmitters yourself:
* Ensure the vehicle is unlocked.
² Place the key in the ignition and turn from LOCK to OFF
and cycle between OFF and ON eight times in rapid
succession (within 10 seconds)with the eighth turn ending in the
ON position. The doors will lock to confirm that programming
mode has been entered.
² Within 20 seconds, program a remote transmitter by pressing any
button on a transmitter. The doors will lock/unlock to confirm that
the remote transmitter has been programmed. (If more than 20 seconds
pass before pressing a remote transmitter button, the programming
mode will exit and the procedure will have to be repeated.)
² Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has
been programmed.
² When you have completed programming the remote transmitters, turn
the ignition to OFF or wait 20 seconds. Again the doors will
lock/unlock to confirm programming has been completed.
Gary M.
White 2002 F250 SD, SC, SB, 4x4, 6.8L v10, 3.73LS, 4spd Auto, Reverse Aid Sensor, Class IV Hitch, Offroad Package, Manual Hubs, 40/20/40 Bench Seat, Camper Package, Lariat, Putco Locker Side Rails, Mud Flaps, K&N Filter, Vent Visors...
White 2002 Ranger 4x2 3.0L V6 XLT 2 door supercab with the power group, auto, chrome wheels, mud flaps, body side molding, vent visors, and the 60/40 bench seat as my daily driver
Old Jan 3, 2003 | 01:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
Gary, -Thanks for the solid info. It will be very helpfull for others thru the years that search for it.
Old Jan 3, 2003 | 05:50 PM
rellik74's Avatar
rellik74
Last spring mine was $48 for the remote and $25 to program it at ford.
For a 98 Ranger
Old Jan 4, 2003 | 07:44 AM
rebocardo's Avatar
rebocardo
You might want to check Radio Shack and pick up a case for $10 and pop your electronics inside, if it fits. I remember seeing replacement cases in neon colors that were sort of see-through.
Or try autoloc and just get a brand new one. I have been happy with my dealings with them. To save you some search for that $8 case:
http://www.autoloc.com/search.lasso?site=autoloc&search=remote. Call for the application, the web site pictures sometimes are not accurate.
