I got Problems!
Old Oct 4, 2004 | 02:20 AM
OldRed460's Avatar
OldRed460
Cool I got Problems!
Hey everyone, ok I got a big problem, i have a 1990 ford F250 with a 460 lots of milage but purrs, jsut recently it starts up when cold jsut fine but after it runs for 30-40 mins and you shut it off, and go to turn it back on the truck will go wump and turn over once and stop. Now if u sit and wait for 5-10 mins it will start. I replaced the starter and nope, so what could it be? Timing? Soleniod?Burnt Fuse? im up in arms about it? PLEASE HELP!
Old Oct 4, 2004 | 04:15 AM
rlangs58's Avatar
rlangs58
Cool Whump Thump & No Go
Check out your battery & Solenoid terminals for clean and corroded spots. Clean the battery terms & make sure cables are clean & tight & be aware
that sometimes when a solenoid is about to quit they will do this then work good after they cool off a little.
rlangs58
Old Oct 4, 2004 | 08:14 PM
kevincook's Avatar
kevincook
I could be a few things / but please check this/ If you have a fuel smell or the engine realy chugs when you get it going mabye you have a injector or 2 leaking down and you are running into hydrolic lock type of a situation./
good luck
