engine control module gets hot
Old Oct 2, 2004 | 04:29 PM
RangerRider460's Avatar
RangerRider460
Question engine control module gets hot
I have a 1977 Ranger XLT 2wd auto 460 C6. I'm having trouble restarting after running for awhile and sometimes it just quits running. I've noticed that the control module is hot and needs to cool down before the engine will restart. I've replaced the module before but the problem has returned again. What causes the module to get hot and what does it do? Do I need to buy a certain brand or make control module?
Old Oct 2, 2004 | 05:55 PM
Mil1ion's Avatar
Mil1ion
Are there spacers under the mounting screw holes?
These should raise the module up away from the fender to allow for cooling.
Old Oct 2, 2004 | 06:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Many aftermarket modules will only last for a few months to a year. If you want a good module get a Motorcraft (OEM type) unit. Many modules have lifetime warranties but that does not pay for a tow bill or decreased fuel mileage. There was a TSB out from Ford on using 1/4" spacers under the ignition module to help keep it cool.
Any electronic device will get hot if it is handling any power. The ignition module gets a signal from a pickup device in the distributor and fires the coil which makes a spark for the plugs.
Old Oct 2, 2004 | 06:43 PM
RangerRider460
No there isn't. I'm going to put some on.
Thanks for the info you guys.
Old Oct 3, 2004 | 05:36 AM
Torque1st's Avatar
Torque1st
Posting Legend
Take your module in to a parts store and have it tested (usually free). They are big fuel robbers if they are not working properly.
Old Oct 3, 2004 | 07:08 AM
damoperator's Avatar
damoperator
Is there any parts store in particular that will perform this test or do I need to check around? Most of the parts guys in the larger chain do not know trucks just computers.
Old Oct 3, 2004 | 02:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Oreiley and Advance both have test machines, others may have them too.
Old Oct 4, 2004 | 12:14 PM
John24255's Avatar
John24255
I have never had to test the module in my truck, but have had others checked by Autozone. They seem to do a fair job.
John24255
Old Oct 6, 2004 | 02:18 PM
CCotten's Avatar
CCotten
I just went through something similar in my truck. It would start and run fine and then not restart, and sometimes would die for no apparant reason and not restart.
The first time it happened I assumed it was the ignition module so I just changed it. Of course all the parts stores were closed at the time so it was the next morning before I was able to purchase the module and change it. It started fine so, of course, the ignition module must have been the problem.
That is until it started dying for unknown reasons and not restarting until it had cooled off. I took the module, formerly thought to be bad, to the store and it tested out fine. So thanks to several posts that I read here, I began to suspect the pick-up coil in the distributor.
I replaced that little device a couple of weeks ago and now I have my dependable truck back. If your module tests OK, I'd suggest you replace the pick-up coil, it's the likely suspect.
Clark
Old Oct 6, 2004 | 04:21 PM
John24255's Avatar
John24255
CCotten,
I had to replace mine last year, it was the original equipment. I didn't have to replace it because it went bad, it seems Ford must have put tasty wires on this module, for a mouse climbed into my engine compartment, and chewed all the wires off of it!
Replacing it wasn't such a bad deal, but you do have to mark the rotors location before removing it.
John24255
Old Oct 6, 2004 | 08:46 PM
funnyboy's Avatar
funnyboy
I never thought of a module causing poor fuel mileage before...how much of a reduction have you seen? And what causes it (a weak or late signal?) or?
Old Oct 6, 2004 | 08:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
Any cylinder misfire will reduce mileage and performance. As far as how much, somewhere between 0 and 100%...
