g'day everyone,
im after a bit of grunt for my old beast so i've gone and got me a 460. in order to get more power i've been looking into stroker kits i.e 501ci, 502ci, and 557ci
the 557 sounds like the go but i don't know much about them. has anyone played with this sort of stuff before. some specs i found were
scat crank 9-460-4500-6635-2220-9000series
scat rod set 2-454-6800-2200-h beams 2-200 jnl rod set
wiseco 4.440'' flat top custom pistons 1.230'' .990pin
and a set of edelbrock 60669 95cc rpm performer complete heads
if any one has got some tried and tested combos for me the info would be most appriciated.
cheers
getuted
Look on ebay, theres alot of different kits out there. Anywhere from 514 to 557 cu. Has anybody run these kits with iron heads? Do you need to go to larger valves?
