Need Help!!
Old Sep 17, 2004 | 12:35 PM
bet7.3's Avatar
bet7.3
Unhappy Need Help!!
Can someone tell me the location on the barometric pressure switch on a 2001 super duty with the 7.3L?
Old Sep 17, 2004 | 02:30 PM
mjwhip2's Avatar
mjwhip2
On my 97 it was up under the dash near where your right knee would be while in a driving position.
Mike
Old Sep 17, 2004 | 03:00 PM
slc10844's Avatar
slc10844
Is this what your looking for? It's out of a 03 manual.
Barometric Pressure Sensor
The Barometric Pressure (BARO) sensor is a variable capacitor sensor that processes a signal indicating atmospheric pressure. This allows the PCM to compensate for altitude. The PCM uses this information to calculate injection timing and glow plug control. The BARO sensor is not a stand-alone component. It is contained in the PCM.
A BARO sensor fault will result in an out-of-range signal to the PCM. The PCM will assume a default value of 100 kPa (14.5 psi).
