1978 - 1996 Big Bronco
Quick question
Old Sep 16, 2004 | 03:37 PM
MatthewC's Avatar
MatthewC
Quick question
Is the one piece front main seal exactly the same as the one piece rear main seal? Need to get at it this weekend.
-Matt
Old Sep 16, 2004 | 03:50 PM
jeep8589's Avatar
jeep8589
No they are not. They work about the same way, but they are different.
Old Sep 16, 2004 | 08:22 PM
BOJOFASO's Avatar
BOJOFASO
not the same but the front main is a lot esier to install. dont need to take to much apart.make sure you have no grooves scraped into the damper because that is what rides in the seal.
Old Sep 16, 2004 | 08:39 PM
MatthewC's Avatar
MatthewC
Just changed the rear main a while ago. Never again. Front main, or timing cover gasket to blame for front leak. Further inspection will find the culprit, both most likely. Also have to check the timing chain, I can hear it rattling at idle. Who knows, that may be the reason for the sluggish performance. Timing seemed alkright when I checked it, but im still getting a click when throttled. Changed brands of gas, upped the octane, still clicking. Assuming that either the timing chain may be streched a little and/or the clogged cats are suffocating the engine causing detonation.
Someday this Bronco will be leak free, and running like a scared rabbit like I know it should.
-Matt
