PCV Problem
Old Sep 16, 2004 | 08:57 AM
FERacing66's Avatar
FERacing66
Question PCV Problem
Okay, the current PCV setup on my truck was a baseplate thing on the bottom of the carb that had a hose that went to the passenger side firewall valve cover. I cannot find one of these pcv setups for a 4bbl carb. Where can I get one? Ive looked in summit and jegs with no luck. Is there some other pcv valve or something I can setup to work instead of the vacum pulling system?
Thanks,
FERacing66
Old Sep 16, 2004 | 10:12 AM
BB's Avatar
BB
Hang out on ebay, they show up on there.
Old Sep 16, 2004 | 11:49 AM
BB's Avatar
BB
Here's some, they get a little spendy depending on how NOS it is:
#7922059189
#7921078823
#2489600147
Aftermarket carbs. have their own PCV port so you don't have to mess with a ported spacer.
Old Sep 16, 2004 | 09:06 PM
FERacing66's Avatar
FERacing66
Does the port in the aftermarket carbs go to the valve cover?
Old Sep 16, 2004 | 09:20 PM
BB's Avatar
BB
It can go any place the PCV is hooked up, usually the valve cover.
Old Sep 17, 2004 | 07:25 AM
FERacing66's Avatar
FERacing66
Thanks for the help.
