Crazy Leveling Question
Old Aug 20, 2004 | 10:50 AM
Motorin Mark's Avatar
Motorin Mark
Just got a new reg cab flareside and dont like the way the back end is up so much higher than the front. I dont want to raise the front to match the rear. How can I lower the rear a bit to match the front?. I'm not interested in "slaming" the truck, just want it level. Is it safe to remove one leaf spring? Thanks.
Old Aug 20, 2004 | 11:20 AM
DesertBound's Avatar
DesertBound
Just buy new shackles. They have a couple different positions so you can somewhat chose the height. They are under 100.00. Removing a leaf is a pain and the ride will get worse.
-Tim
Old Aug 20, 2004 | 11:51 AM
Motorin Mark
Sounds easy enough, Where do I find them? Is this a Ford factory part or aftermarket? Any part numbers that you guys know of? Thanks.
Old Aug 20, 2004 | 10:29 PM
Toreador's Avatar
Toreador
If you do a search with a combination of the words "leveling +kits" or lowering +kit you will find a lot of posts about different lowering kit products. Here's one that names some of the products: https://www.ford-trucks.com/forums/s...ht=lower+kits+
Old Aug 21, 2004 | 12:01 AM
derbystud's Avatar
derbystud
Remove the blocks that are between the rear axle and the springs. We just sold a new pickup to a older guy and he had us remove the blocks. It drops it down the perfect distance and makes the front and back level. The threads on the u-bolts arent quite long enough so your have to add some washers. It dont cost any money and its easy.
Nathan00
2004 - 2008 F150
Jan 20, 2015 10:54 AM
the cleaner
Modular V10 (6.8l)
Aug 7, 2014 06:59 AM
highoctane74
Jun 1, 2014 06:07 PM
bretjackson
1997 - 2003 F150
Oct 7, 2003 06:27 PM
