blinking headlights
Old Aug 12, 2004 | 04:14 AM
volfan945's Avatar
volfan945
blinking headlights
can anyone tell me what would cause my headlights to flicker , they don't go off but it is like they are getting energy surges.. thanks
Old Aug 12, 2004 | 07:27 AM
19gator55's Avatar
19gator55
I have had a similar problem in the past and it was the alternator overcharging the system. It was putting out about 16 volts. Actually I guess it was the voltage regulator inside the alternator. If you have a seperate voltage regulator check the output voltage or else check the output voltage on the alt.
Old Aug 24, 2004 | 03:19 PM
t_g_farrell's Avatar
t_g_farrell
I had a problem like this, see my response on this thread for deatils. I rewired the headlights to use relays to avoid an overheating headlight switch.
https://www.ford-trucks.com/forums/s...87#post1881287
