Performance 2.9 Help
Old Aug 10, 2004 | 11:25 AM
Psychopete's Avatar
Psychopete
Hey, I was wondering if someone could point me in the right direction on getting my engine started for the first time.
Here's what I am dealing with: (1988 Ranger)
2.9L V6
90' MAF ECU
19LBS. Fuel Injectors
Pace Setter Headers
Colt Cam:
INT: 210° .435 Lift
EX: 216° .450 Lift
111 LDA
.037" longer push rods
.035" milled brand new casted heads
New water pump, and oil pump
IST Air Adjuster
MAF off a stock 5.0L
58mm Throttle Body
Crank has been polished and the engine has been hot tanked and honed. I also had the machine shop put in my cam bearings and cam. He was saying the 2.9 was one of the hardest to put cam bearings in, so I didn't want to screw it up.
There's probably more I missed, but I am worried about getting the timing right, and getting the engine fully primed. Also will the stock fuel pressure regulator be sufficient for the 19lbs injectors, or will I need to replace it? Can anyone recommend a setting that would be close on the IST air adjuster? (Keeps me from getting my MAF calibrated) Does anyone recommend using a good type of lube for the rod bearings and main bearings? How long do you think the transmission will last and will a 4.0 A4LD be sufficient? Any suggestion, or tip or anything is extremely helpful at this point. I am very knowledgeable with small engines, tolerances, and general mechanics. This is the first engine I am rebuilding, and honestly I have no clue what the h3ll I am doing. I only rebuild the engine because of cracked heads, and the water in my oil caused my lifters to gunk up and tick.
Thanks in advance,
Pete
bismic
Aug 10, 2015 10:35 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
hughjazz
2004 - 2008 F150
Jun 25, 2012 11:42 AM
RANGER589
18
Jun 3, 2011 10:03 AM
rusbukt
Jun 3, 2008 08:01 PM
