Timing problem
Old Aug 5, 2004 | 07:20 PM
Bronco2big's Avatar
Bronco2big
Unhappy Timing problem
Hey guys, I have an 84 Bronco with a 4.9. It is pinging under load. Ive checked the timing and it is right on spec.
After I set the timing I plugged back in the wire that controls the advance, and the timing mark goes off the scale. Is this normal?
I'm thinking of going to a mechanical advance distributer. Do you know of someone that makes one for the 4.9.
One other question, My Bronco is carborated. Does an EFI intake make a difference. Thanks.
Old Aug 6, 2004 | 08:45 AM
FordF150Fixer's Avatar
FordF150Fixer
Your timing is controlled by the computer. The computer may be trying to apply too much advance because something is wrong with one or more of its input sensors. I would suggest pulling the codes to see if anything is out of specs on any of the various inputs.
If you decide to replace the ignition with one that has vacuum advance, the Ford DuraSpark II is an excellent choice. If you get a DuraSpark II distributor, wiring harness, and module from a junk yard, it’s a drop-in plug & play modification. I got mine from a local junk yard for $36.
If you install a DuraSpark ignition system, the computer no longer has anything to do with the ignition system and you have the option of replacing the computer feedback carburetor with a non-computer controlled carburetor. There are many carburetor options including after-market manifolds and four barrel carbs. However, those options should be exercised with some caution. Your local emission laws may not allow you to do those modifications.
Old Aug 7, 2004 | 12:26 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Mine does the same thing... Except mine has vaccume to the distributor and is a duraspark II. It's very normal, at least for my engine caliberation.
The Carb is caliberated to the distributor so it does this by design, and inbetween the carb and distributor vacume line is a spark retard solonoid, that the computer uses to bleed off the vaccume when the engine shuts off or it senses pinging.
Check and see if your knock sensor is bad.
