A/C Blower problem
Old Aug 4, 2004 | 10:45 AM
RVBfordman's Avatar
RVBfordman
A/C Blower problem
My A/C blower on my 96 full size Bronco starts blowing our the normal AC vents and then shifts to the defrost vents and then shifts to the floor vents. Does all of this randomly. What do you think is causing this?
Old Aug 5, 2004 | 12:43 PM
Pikachu's Avatar
Pikachu
Vacuum problem somewhere. Are you sure its random, and has nothing to do with how much throttle you're using?
Old Aug 5, 2004 | 12:53 PM
RVBfordman's Avatar
RVBfordman
It may be related. I noticed that the times that I had the biggest problems was when I was pulling a trailer with a medium size load on the trailer, which means I was having to provide more throttle to keep the speed up. What do you think is causing it, if it is related to the throttle?
Old Aug 5, 2004 | 02:33 PM
Pikachu's Avatar
Pikachu
Probably a vacuum leak or bad check valve in the vacuum system. The more throttle you apply, the lower the vacuum goes. If there is a bad check valve, or leak it could produce the symptoms you describe.
Old Aug 5, 2004 | 03:58 PM
RVBfordman's Avatar
RVBfordman
Thanks, I'll give it a look see. I hadn't thought about the throttle issue until you asked it and it has occurred when the truck has been pulling a trailer.
Where is check valve located?
Old Aug 5, 2004 | 05:48 PM
Pikachu's Avatar
Pikachu
I honestly don't know where it would be on that truck. Perhaps someone else around here will chime in....
