Sound System and tires
OK 2 Quick Questions.
1 - Will the factory deck with the indash 6 CD changer work in my truck that has the single CD player? I listened to one that was in a Mustang and I love the sound and the 6 CDs.
2 - What is the largest size tire that I can put on my stock '02 F150 SCab 4x4? I am waiting for the new ones that came with the truck to wear out then gonna go with the BFGs AT/KOs.
Thanks all!
Thanks all!
I don't know what your paying for this factory Ford CD player but the one you heard in a Mustang has an external amp. So not only wont it sound the same but if your actually buying this radio for the sound benefit you might want to look into an after-market radio. They put out much more power and a lot cleaner power at that. Stock Ford radios are nothing to brag about.
As for tires if you do a torsion lift and cut a little plastic you can cram 315/70/17's, other wise you can get away with a 285/75/17
Originally Posted by 5.4AZ4X4
I don't know what your paying for this factory Ford CD player but the one you heard in a Mustang has an external amp. So not only wont it sound the same ..........
As for the tires, I am running 16in rims on mine right now.
You have an extended cab? I should see if i can load some pictures of my install. I have 2-12in subs that are in a box under the rear seat. I mounted the rear seats onto the box. I had to remove all the brackets and whatnot. I am running 2 amps. 1 is under the passenger seat (had to remove spare tire tools). The other I have in the center consol, its a pretty cool set-up. NOTE!! ALL of your stupid idiot Ford vacuums for your 4X4 and your A/C controls are right next to the battery. When you run your power wires keep them clear of the vacuum lines. Stupid stupid stupid Ford. Anyhow, if you have any questions or help with anything Im glad to help.
