Sponsored by: Auxito
Lean Mixture Trouble Codes Fixed !!
Old Jul 26, 2004 | 11:15 PM
jvaski's Avatar
jvaski
Smile Lean Mixture Trouble Codes Fixed !!
Problem Solved ! 1998 F150 4x4
Been having Lean Mixutre trouble codes triggered every time I left altitude and pulled the first hill on my way home in the mountains.
Left a message on this site - and Racerguy directed me to a tech bulletin regarding Baro sensor, and MAF sensor contamination.
After running tests with my auto xray scanner I determined that the MAF sensor was funtioning poorly. I removed the MAF sensor, carefully cleaned the two wires with chemtool carb cleaner and a Q-tip ( the wires bend very easily so be careful ). The wires had some black tar like substance on them . After re-installing the MAF sensor I disconnected the battery for about ten minutes to erase the KAM ( keep alive memory learned ) .
Re- testing the MAF sensor warmed up and at idle - it was now well within the operating range it should be ! I have since driven the truck off the hill and happy to report - NO TROUBLE CODES - NO LEAN MIXTURE BANKS 1 & 2 !!!
Thank you Racrguy for your very specific help on this one !!
John A , Lake Tahoe, Ca
Old Jul 27, 2004 | 01:03 AM
Racerguy's Avatar
Racerguy
You're welcome
Good to hear that you got it fixed.
Old Jul 27, 2004 | 01:12 AM
jvaski's Avatar
jvaski
Thanks Dave
Dave, thank you very much for your help on this !
Old Dec 26, 2004 | 06:01 PM
fordinlinesix's Avatar
fordinlinesix
Yup, happens a lot, glad it's an easy fix.
gman97005
Oct 25, 2013 03:38 AM
1978Crew
Escape & Escape Hybrid
Mar 5, 2012 06:23 PM
Turdle
Modular V10 (6.8l)
Oct 11, 2011 07:10 PM
richmone73
Bronco II
Jan 8, 2011 11:31 PM
case2k5
Modular V8 (4.6L, 5.4L)
Sep 18, 2005 05:20 PM
