Sponsored by: Real Truck
help!!!
Old Jul 24, 2004 | 04:43 PM
99PSDCREW's Avatar
99PSDCREW
help!!!
I'm changing the Sonnax valve and tricumulator springs. Sonnax valve is in . I pulled the retaining spring of the 3-4 gear spring-assembly out and can't get the rest out to replace the spring. It seems stuck (but moves), and I don't want to force anything.... Can somebody tell me what I should do?? Thanks everyone
99PSDCrew
Old Jul 24, 2004 | 05:02 PM
99PSDCREW's Avatar
99PSDCREW
I called Techtranstool.com (where I bought them) in Utah and he was actually there on Saturday. Anyways, I took one of the bolts from the valve body and screwed it into the end and pulled it out that way. Worked great. Kudos to Techtranstool
Old Jul 24, 2004 | 05:16 PM
wlihntr's Avatar
wlihntr
i had a similar problem when i did mine. i my case even with the bolt screwed in i could not get the cap out. i had to put a pair of pliers around the bolt and lightly tap against the the bolt head to get the cap out.
