Engine Pulsates
Old Jul 21, 2004 | 10:37 PM
Fomoco1546's Avatar
Fomoco1546
Question Engine Pulsates
Hi, I have a 1979 F-250. I replaced the carburator a few months ago. When I go up hill over rough terrain, the truck will start to buck or pulsate. It will do this to the point that I have to push the clutch in, stop, and start out again. When I do push the clutch in, it idles fine. could this be from not enough fuel in the fuel bowl and it's causing this? I'm not sure it's even carb. related. Any help would be much appreciated, Thanks
Old Jul 21, 2004 | 11:32 PM
78f250RangerExplorer's Avatar
are you four wheeling or are you highway driving?
Old Jul 23, 2004 | 09:24 PM
Fomoco1546's Avatar
Fomoco1546
Sorry, I did not explain myself. It runs super on the highway. It will pulsated in 4WD 1st gear on rocky, steep incline. Thanks
Old Aug 20, 2004 | 10:28 AM
1970f2504x4's Avatar
1970f2504x4
Did one of your spark plug wires fall off? I've had this happen a few times - it's especially noticable on inclines. Also check your fuel filters.
Old Aug 24, 2004 | 10:46 AM
RaleighDad66's Avatar
RaleighDad66
A damper was used to help eliminate float bounce in 4X4 carbs. You might check to see if that is installed. Also, does it only have problems in one particular direction (up, down, left or right incline) or when the tank is full vs. empty? Pick-up tube in the tank or a low float setting in carb may be contributing factors.
Old Aug 25, 2004 | 08:31 PM
Fomoco1546's Avatar
Fomoco1546
Engine Pulsates
The truck only pulsates going uphill. I adjusted the float level a little higher, but problen still persist. Anyone know how much fuel should be in carb bowl, measuring from top of carb, with air horn off? Thanks
Old Aug 26, 2004 | 07:17 AM
RaleighDad66
What carb and engine? I have a chart with levels for the 2100 series if that is what you are using.
Old Aug 28, 2004 | 08:20 PM
Fomoco1546's Avatar
Fomoco1546
Engine Pulsates
I have A 2150 2b on a 351M. Thanks
totavikid
Apr 24, 2013 01:35 PM
78 Ranger
Electrical Systems/Wiring
Feb 18, 2008 06:21 PM
96eddie5.8
1978 - 1996 Big Bronco
Dec 17, 2006 11:31 AM
mark b
Dec 16, 2005 07:18 PM
JoeBlow
17
Nov 4, 2005 04:33 PM
