electrical lighting problems please help
Old Aug 15, 2002 | 02:53 PM
Ian Poush's Avatar
Ian Poush
1991 eddie baur edition explorer
as soon as i press the brakes the fuse for the lights blows, and when i use my directionals the left will work, but the right will blow the fuse just as fast as the brakes do. Any suggestions.
Old Aug 15, 2002 | 03:29 PM
Dialtone's Avatar
Dialtone
You have a short to ground on the power lead supplying the right side turn signal/stop lamp circuit. Could be a blown bulb that shorted internally or a lead insulation cut thru somewhere. I would start by removing all the bulbs on the right side circuit and check for ground on the power supply lead to the bulbs with a volt/ohm meter. If meter shows no short, then check bulbs one at a time till you find shorted one (shows very low resistance, if in doubt what is low, compare two or three for a baseline reading).
Dialtone
Old Aug 16, 2002 | 07:59 PM
Opera House Works's Avatar
Opera House Works
Post electrical lighting problems please help
When I have to diagnose shorts, I replace the fuse with a headlight bulb. I always have a couple of these lamps around with one section blown out. Wire it up to a couple of 1/4 inch spade connectors. These fit easily in the connectors for the fuse tangs. Place the lamp(s) where it can be seen. With a complete short, the lamp will be full brightness and the wiring will be protected. You can then wiggle and unplug things till you see a change in lamp brightness. I've even used two, three or four lamps in parallel to run windshield wiper motors. Figure 5A for each lamp. Sure saves on the fuses!
Old Aug 16, 2002 | 10:48 PM
adc454's Avatar
adc454
jmuenchow
15
May 31, 2020 09:57 AM
geminijay313
May 23, 2014 11:45 AM
Stroker 6.0 fan
Oct 25, 2013 04:20 PM
bowler300623
Jan 23, 2012 02:41 PM
syannuzzi
Electrical Systems/Wiring
Dec 18, 2006 07:15 PM
