Sponsored by: Auxito
Lean Mixture - Trouble Codes
Old Jul 5, 2004 | 12:34 AM
jvaski's Avatar
jvaski
Question Lean Mixture - Trouble Codes ??
Whenever I take my 98' F150 5.4 liter truck to lower altitude - I get the check engine lite and trouble codes for lean mixture banks 1 & 2. ( upon returning to altitude) ( I live at 6000ft elevation )
The trouble codes only trigger after I leave altitude - and trigger upon return & pulling a steep hill. MAF tests fine and is clean. Fuel filter is new. IAT is clean and tests fine.
Anyone else have the same problem, or know what might cause this ?
Old Jul 5, 2004 | 11:18 PM
Racerguy's Avatar
Racerguy
Hi jvaski and welcome to the forum
I haven't seen that problem before so I'll just have guess here.
I think you have a MAF problem. It might not set a code but still could have a problem. If you could monitor live data you might find it.
For some interesting reading that might apply take a look at http://www.v8sho.com/SHO/TSB982310Ma...tamination.htm and notice where it talks about BARO.
Old Jul 5, 2004 | 11:54 PM
jvaski's Avatar
jvaski
Lean Mixture codes
Racerguy - Thanks very much for the reply and the excellent reading on the problem I'm having !
I'm taking my real-time scanner with me the next trip off the hill to watch for the problem. The writeup aslo said to try WOT a few times to reset BARO .
I'll give it a shot . Then maybe it's time to try replacing the MAF or looking for contamination.
Thanks again - you've been a great help !
John A
Old Jul 5, 2004 | 11:57 PM
Racerguy's Avatar
Racerguy
Please let us know what you find.
I'm curious about this one too.
Old Jul 18, 2004 | 01:13 AM
jvaski's Avatar
jvaski
Lean Mixture trouble codes
Dave, Thanks for the Tech page on MAF sensors and BARO .
I ran a test at idle for Long Term Fuel TRIM and found the MAF sensor was beyond -12 which indicated contamination . I pulled the MAF sensor and used a Q-tip with Chemtool carb cleaner to gently clean the wires . The MAF sensor is now operating in normal range. I will let you know if it also cured the lean mixture codes when I change altitude .
Thanks again for the help. !
John
Old Jul 18, 2004 | 10:23 AM
Racerguy's Avatar
Racerguy
It sounds like you're on the right track there.
We had a MAF problem on one at work the other day. It ended up being that the rubber grommet where the MAF wires go into the air fliter housing was out of it's hole and allowing unmetered air in. It was a simple problem but took a while to find.
Old Jul 18, 2004 | 12:39 PM
blueharley's Avatar
blueharley
I have a 98 4.6 and have had the same problem. I clear the code and it does fine for a while then get the light. No vacum or manifold leaks so waiting for something to hard fail. Where I live we use the oxygenated gas Oct thruough Mar and that is when I started having the problem. Have not had the light since we switched back to regular fuel.
Old Jul 19, 2004 | 12:08 AM
Racerguy's Avatar
Racerguy
Interesting that the fuel seems to make a difference.
Anyone else ran into that?
