Computer Chips & Tuners
reading codes.. plz help
Old 07-03-2004, 08:25 PM
Trav460's Avatar
Trav460
Trav460 is offline
well picked up a OBD1 today to help solve my problems.. anyways with the key on truck off i got these codes 116, 542, 556 and the book says
116- engine coolant temperature higher or lower than expected
542- fuel pump secondary circuit fault
556- fuel pump relay primary circuit fault
so does anyone no wut this means? wuts a circuit? is it saying i need a fuel pump? or just a relay? i just don't understand wut its saying.. if n e one can help me clear this up.. as for the coolant temp im gona try a new censor for the firts part
Old 07-03-2004, 10:43 PM
goingfor3's Avatar
goingfor3
goingfor3 is offline
for the fuel pump codes, check for corrosion at the fuel pump relay. Have seen this before, but it could still have other issues with fuel pump.
Old 07-04-2004, 11:13 PM
tkondro's Avatar
tkondro
tkondro is offline
Erase the coolant temp code and run the truck for a couple days and see if it shows up again. It could have just gotten hot one day. If not it would be the sensor.
