Symptom of trans pump going out
Old 06-28-2004, 11:26 AM
glenn Allen's Avatar
glenn Allen
glenn Allen is offline
Trans workes perfect when cold. But startes to delay going into gear when warmed up. Also it will not engage right off the line until the rpm hits about 1k. It pulls on its own at idle, but once you try to accelerate it hits a neutral for a second then re-engages. It does this in drive, manual 1 and manual 2 and reverse. I can power brake it and make it engage then it will fry the tires. Everything else works fine on the trans and I am suspecting some kind of pump issue. Anyone have any other ideas?
