429 or 460 ??? DOVE-C
first off welcome to FTE
Now IF the intake is original to the engine then yes it would be a 429, they never used 2bbl carbs on 460s but remember some people did swap them on to try and get better fuel economy (doesn't work though a 4bbl running on just the primaries will do better then a 2bbl carb)
Now if you KNOW that manifold is original to that engine your set but if any doubt the only way to tell is measure the stroke or look for casting numbers on the crank
well if you have the heads off it's easy just measure with a tape measure, if you don't have the heads off you can do it with a heavy wire through the plug hole (like mechanics wire or a coat hanger) Mark it at tdc then slowly rotate the engine to bdc and remark then measure if the marks are approx 3-1/2 inch it's a 429 (429 is 3.59" stroke) if it's over 3-3/4" it's a 460 (460=3.85" stroke)
Well on my some of my race engines i never put them in to start with, really won't hurt a thing as long as they don't plug up the oil pickup. clean out as much as you can from the heads. Basically all that will happen is you will have some blue smoke on cold start up. I have seen many many engines with over 100,000 on them AFTER the valve seals go away. If you can get the pan off you could clean it out of it makes you feel better but honestly it's not a deal breaker as it will run just fine.
If you really feel the need and the smoke at start up bothers you, you can replace them without removing the heads using comprssed air and a on engine valve spring compressor but like i said personally on a toy I wouldn't even bother.
Monster, I am getting close to buying a rebuilt long block. I'm debating whether to go with a 429(early 70's with dove-c heads or a 460. It will have a mild cam Edelbrock performer, and intake as well as a 750 cfm edelbrock carb(all matched). Some say go with the extra cc's others say the 429 will have more get up and go. What do you think?
It's going into a 48 Ford F1 truck with a c-6 tranny, and a 9 inch rear end, with 3.0:1 gears.
honestly if your not thinking of a stroker it's 6 of one half dozen of the other. The 460 will have a slight advantage in torque, as a base engine the 429 will tend to rev a little faster but your only talking 31 ci so you MIGHT have a 30hp 40ft/lb advantage with the 460, but if your not racing and looking for all it can the 429 just sounds cooler when you tell people what motor you have.
460
I have an 85 ford f250 with a 460 with about 170,000 miles on it
i compression tested it and there is no less than 140 in all cylinders and no more than 145 its a daily driver but i love four wheeling
and i came across a ford 429 with some dove-c heads. I have a pretty low budget and i would like some more power out of my old 4X4. i was looking into just replacing the cam but now i dont know what do you guys think
#29
Lets see, you have a known good engine with a clean bill of health as far as compression test goes vs an unknown questionable engine that may need a complete overhaul AND a new cam to get any power out of. Personally i would keep the known engine, change out the timing chain for a double roller and set it straight up, a good free flowing exhaust and possibly a cam and intake depending on budget.
IF you want you can then build one to replace it with later out of the 429 but I wouldn't get rid of an engine that is running good.
#30
Thanks alot, i plan on buying this cam if u wouln't mind taking a quick look and telling me what ya think
COMP Cams: High Energy™, 260H: Cam & Kit
thanks again
thanks again
