starter problem
Old Jun 3, 2004 | 11:59 PM
tye sheats's Avatar
tye sheats
starter problem
hi, I just did a full engine swap on my 77 f-100 with a 351m and when I turn the key over the starter sometimes doesn't stop, it just keeps turning its teeth like its stuck on, i believe the problem is in the wiring maybe around the silenoid(sp) but dont actually know what the problem is ??? help me please thanks tye
Old Jun 4, 2004 | 01:24 AM
Mil1ion's Avatar
Mil1ion
The next time is keeps cranking pull the 90* plug off the S terminal of the Solenoid.
It should should stop cranking.
It could also be the starter drive needs lubricating.
I have a engine that I let sit for 3 years, when I turned the key, It would shut down.
I think it's a faulty Solenoid.
Good Luck.
Old Jun 4, 2004 | 12:09 PM
Franklin2's Avatar
Franklin2
Dennis is saying pull the wire off point #5 to see if it quits cranking. There is a large set of contacts that switches point #3 and #6. that could be welding themselves together occasionally.
