There have been cases where the Duraspark modules have failed, and there is nothing you can do but replace it, as it is completely potted inside. The other common failure is the trigger amplifier that's bolted to the side of the distributor. As they get old, they become more sensitive to heat, and will fail when they get too hot. Then they will work again when they cool down enough, then repeat the cycle. The permanent fox for that (after replacing the module) is to bolt them to an inner fender, away from the main stream of hot air. This will require a longer wiring harness.
