leave engine on when refilling???
Originally Posted by 03f350crew
I thought it was the other way around. You are supposed to ground yourself to the vehicle before touching the nozzle so that you don't get a spark from static. I think the idea is that any static in you will be taken from the vehicle rather than touch the nozzle and get a spark. ![Hair](images/smilies2/smhair.gif)
Originally Posted by csherman4383
Leave them engines running...............won't hurt but help you not to melt your turbo and extra wear and tear on your starter..............just don't ground yourself to your truck while fueling.......!
FIRES AT REFUELING SITES THAT APPEAR TO BE STATIC RELATED
February 17, 2004
Compiled and written by: Robert N. Renkes
Executive Vice President & General Counsel
Petroleum Equipment Institute
P.O. Box 2380
Tulsa, Oklahoma 74101-2380
(918) 494-9696 (phone)
(918) 491-9895 (fax)
rrenkes@pei.org
Reports by Year
Year Total NHTSA Only
1992 1
1993 1 1
1994 3 3
1995 8 7
1996 7 4
1997 9 5
1998 10 3
1999 32 6
2000 23 1
2001 12
2002 31
2003 12
2004 2
Unknown 7 4
Total 158 34
Now consider the number of refueling operations that go on daily. According to PEI "Americans pump gasoline into their cars between 11 and 12 billion times a year without incident". See more at http://www.pei.org/
most places I fill at are at least 5 minutes off the fwy so I usually pull in, Idle for a minute or so then shut it down. I'm usually putting in 30-35 gallons so its gonna be a few minutes,especially topping off the last 3-4 gallons.
I shut down mostly as a courtesy to the others filling up at the station.
Originally Posted by johnsdiesel
Diesel won't ignite from a spark so don't worry about it.
Years ago I watched a poor guy die when he had his car parked too close to a campfire. He heard a hissing at his gas cap and without thinking he opened it to let off the pressure before he started it and it pushed the vapors right into his lungs as he gasped in amazement. The fumes then ignited burning him inside and out. I was at quite a distance and it happened so fast nobody could do anything.
I have welded aluminum tanks without completely washing them out and got away with it, but we all do stupid things when we are younger. I have also thrown matches in cool diesel fuel but never had the motivation to try it at the 150 degree mark. Like they say on TV, don't try this at home.
Originally Posted by MaXRSmart
I will let it idle if it is diesel only pumps. If it is a mix pump with gas and diesel, I will shut it down. But if I was running it hard before getting to the station, I will let it idle.
I make sure the last mile, open road, is very easy on the throttle……….before fueling
#29
#30
turboglide, I tossed a light match into a paper cup of diesel about 1 year go to see if it was true and it did not ignite.
