HELLLLLLPPPPPP!!!! Sick Powerstroke!
Old Jul 7, 2002 | 02:39 PM
wildjon300ci's Avatar
wildjon300ci
My dad's powerstroke is sick. It has a definate miss and the SES light comes on when it happens. I'm thinking it could be a bad glowplug because once the engine heats up it'll go away until it is allowed to idle or run at a slow speed. When I load the engine (I.E. up a hill in overdrive), once I hit the top and take the load off the engine, it'll quit missing and the SES will go off. It's like trying to start a cold gasser with no choke, you gotta play with the throttle to make the cylinder hit.....Anyone else have any ideas, I'm gonna try to have the codes read sometime soon, hopefully tommarow.
P.S. The oil was missing only two quarts (about 1200 miles 'till oil change time) and I topped it off just to make sure it wasn't that...and I have already ruled out bad diesel, two full tanks gone.
Old Jul 7, 2002 | 07:15 PM
The Diesel Dude's Avatar
The Diesel Dude
If your "service engine soon" light has been on then there is a code that has been set in the computer. You need to retrieve the codes from the computer and service the first one first. Your type of problem is the easiest to deal with because the computer tells you right where to look.
Old Jul 8, 2002 | 07:08 PM
wildjon300ci
Well, I know know the problem, which is what I feared. The #7 injector has died. The truck is only 8290 miles outta engine warrenty. Oh well, I guess that's just how life goes.
Old Jul 8, 2002 | 07:32 PM
The Diesel Dude
What is the year and mileage of your dad's truck?
Old Jul 8, 2002 | 07:39 PM
wildjon300ci
1999.5 F-350...The mileage is 108,692 miles...
Can you check it out? The engine codes are KE 002 BC
0976283
Built? 11 Mar 99
Old Jul 9, 2002 | 01:53 PM
The Diesel Dude
I can (and will) check your serial number in our data base but it is unlikely that there is anything there that is pertainent to an engine with 108,000 miles on it. Your truck has the new style injectors in it, which surprises me that one has crapped out on you.
Old Jul 9, 2002 | 02:08 PM
The Diesel Dude
If you are going to change this yourself, be sure to drain the rail before you remove the injector. If you don't, you run the risk of hydra-locking the cylinder and bending the connecting rod.
Old Jul 9, 2002 | 02:55 PM
sthoge's Avatar
sthoge
Joe,
Do you have to drain both rails? (Fuel and HP oil)
Steven Hogeweide
2000 F350 XLT PSD 4X4, 6spd, ESOF, 4.10ls, Super Cab Dually, Tow Pkg, Camper Pkg, Off Road pkg, Western Diesel Power Chip, AutoMeter EGT and Boost gauges.
Old Jul 9, 2002 | 07:17 PM
The Diesel Dude
Steve:
I've never done one in the truck before but I don't think so. Drain the H/P rail (after you remove the drain plugs you'll need to take out one of the cross drill plugs on top of the rail or it won't drain) and remove the lower injector bolt, push the injector clamp forward (toward the intake side of the head) and pry the injector up enough with a screw driver so that you can lift it right out. When you get ready to pull the injector out of the bore, have the new injector in your other hand and when you pull the old one out, stuff the new one in right away, that way you'll minimize the fluid entering the cylinder (we can change them at the plant that way without draining either rail but it is a lot easier working on the engine when it is not in the vehicle).
I checked your serial number in our data base and, as you indicated, it was built 3/11/99, went straight through the system with no defects. The horse power and other performance characteristics have all been down loaded to a system I don't have access to.
Old Jul 9, 2002 | 09:46 PM
wildjon300ci
Thanks man.......The new injector has been put in and the ole' girl is back to herself. The only problem is that $450 has left the building. :-staun
Old Jul 9, 2002 | 10:32 PM
twbuild's Avatar
twbuild
