transmision problem
Old Aug 17, 2002 | 01:42 AM
Quadzilla's Avatar
Quadzilla
transmision problem
Old Sep 9, 2002 | 07:48 PM
TRIMMAN98's Avatar
TRIMMAN98
transmision problem
2002 PSD AUTO AFTER TRANS GETS TO OPERATING TEMP IT LIKE ITS IN NUTRAL IF COASTING WHEN IT GETS DOWN TO 40MPH ENGINE GO TO IDOL ONLY 12,500 MILES
Old Sep 9, 2002 | 09:38 PM
rlarkin's Avatar
rlarkin
transmision problem
Here is the test.
Take the truck up to 55 with the OD locked out. Let up on the pedal and watch the tach. If it imediately goes to idle, you prolly have a bad coast clutch. Dealer time.
If the tach drops slowly with the speedo until about 38 mph, then drops to idle, you are prolly normal. The T/C will unlock at about 38 mph durring decel.
