Backfiring
Old Apr 23, 2004 | 01:40 PM
andyjack's Avatar
andyjack
Backfiring
Any suggestions? I have a 1951 Ford P/U with original flathead. When you let off the gas the it backfires. Tried adjusting the timing-didn't work.
Old Apr 24, 2004 | 01:00 AM
laynrubber's Avatar
laynrubber
I don't know but i can give suggestions.........
Backfires out the carb or out the tailpipe ?
carb settings should be checked, maybe too lean
all timing checked......point gap, advance working ?, plug gaps
compression of each cylinder.
Keep us informed.
Old Apr 24, 2004 | 07:43 AM
tp's Avatar
tp
Andy- I had this pbm on an old VW Beetle years back. Mixture was too lean. Adjusted carb to make it right and pbm was gone. tp
Old Apr 26, 2004 | 03:26 PM
andyjack's Avatar
andyjack
Will give them a check--Thanks
Old Apr 30, 2004 | 01:55 PM
kevin69's Avatar
kevin69
Thumbs up
I have this problem with my 50 F-1. It is the points. They close so often and that is what causes the backfire. I have been told an electronic ignition will solve this problem.
Old Apr 30, 2004 | 05:43 PM
Jag Red 54's Avatar
Jag Red 54
I also vote for the points being the problem. Did you solve the problem? John
Old May 1, 2004 | 11:41 AM
kevin69's Avatar
kevin69
Smile
John. I have not yet financed a electronic ignition. I will be getting the truck re-wired. So I am saving up for that. Will let you know about it when I do it.
Old May 2, 2004 | 09:08 AM
tp's Avatar
tp
Kevin-I'm not sure what you mean by the points closing so often. If you haven't already tried putting in new points and adjusting the dwell, it's worth a try before going to expense of a new ignition system. Terry
Old May 2, 2004 | 09:52 AM
kevin69's Avatar
kevin69
Smile
I believe I had new points put in about a year ago. The backfiring was gone for awhile and now it is back,but only when the motor is cold. Also I have this diamond plated back bumper with matching side plates that the tail lights are incorporated into. Was this a factory ad or after market?
