Rear mount-side fill gas tank, has anyone done this set?
Thinking of putting gas tank in the rear but I don't care for the fill being in the bed. I know I can get a tank and a c-notch for the frame. If anyone has made this move and have or know where to look at some pictures that would be great. , thanks, Bob
i have mounted a rear mount tank from a early 90's suburban in the frame rails, and put a buick gas door on the side of the 50 f1 panel, the fill neck comes out of the top of the tank, goes between the frame and the flooring, wraps around the wheel well and the filler is in the left fender, should be some picks in my gallery.
Bob., I am using a gas tank and skid plate from a Jeep cj. The tank is 15 gallon and they come in steel or plastic. I have the tank, skid plate, electric fuel pump, fuel filter & sending unit mounted. The fill & vent hoses will come out the driver side between the frame & the bed. I am going to mount the fill cap on the driver side rear fender. Right now the bed & fenders are not on the truck. I can send pictures if you are interested.
There are a couple of F-100's running around in my area...a 58 and a 59. that have side fill tanks, the filler necks are in the bed rear of the wheel wheel well. the neck is about 8" above the floor and is boxed in on the inside of the bed. I havent had a chance to look at them closely or to talk to the guys on them. It looks good, but I would prefer a driver side fill. Im sure there was some cutting to get them in there. the boxed in area is 6 inches wide and the height of the filler and about 5-6" deep
Glack
Glack
on
isuzu tank answer
Bob,
several years back June/96 CCT ran an article on installing a isuzu rodeo ( i think) tank in a f-100... c notched the left frame rail and ran the filler to the left rear fender if I rmember right. you might try finding that article ... if you don't have it I probably have a zeroxed copy somewhere at work I can fax or mail you... might be able to scan it in and email if the copy is good enough..
later
john -X06
later
john -X06
Originally Posted by jniolon
Bob,
later
john -X06
later
john -X06
Hi John, thanks, copy via email would be great. How many gallons is a isuzu tank? Bob
If you are still working it...
I did this exact thing and it has worked well. Brought it out the top curve at the rear of the driver side rear fender. The only issue I have had with it is if you go to refuel with the truck leaning to the driver side (slight incline at the pumps) the fuel will pool in the filler hose between the bends at the bed and the tank, and it will take a month of Sunday's to fill your tank. Just pay attention when you pull into the pumps.
Matt and "Toulouse" '48 F-1
