Ford mudflaps
Old Apr 20, 2004 | 02:06 PM
WhiteNight's Avatar
WhiteNight
Ford mudflaps
However the factory ford mudflaps don't fit worth a crap.I tried two sets and they do ''NOT'' mount vertically.When mounted the bottoms are kicked in at least an inch on the rear and maybe 1/2" on the fronts.All holes line up on the front ones and as indicated in previous threads the bottom holes on the rear do not.I did mount them but kicked out the rears to vertical.The fronts I left as mounted as they are not as noticable with the factory bright boards.For your info the mudflaps for the 04 F150 "without" the wheel lips mount fine.
