Sponsored by: Auxito
tachometer install
Old Apr 13, 2004 | 10:02 AM
bigpowerstroke's Avatar
bigpowerstroke
Question tachometer install
I am installing a tachometer on a 2003 ford f150 4.2L , I am having a little trouble figuring out which wire at the PCM to use. I know on the '98 models it is the white wire with a red stripe, connector 104, pin 48. That wire doesn't exist on this truck, If anyone has done this install let me know how you did it.
Old Apr 13, 2004 | 11:24 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
I believe that on your truck you will need an adapter to wire up the tach, such as the one at http://www.egauges.com/pdf/AutoMeter/561.pdf or http://www.exclamationagiftshop.com/...ms_tach_.shtml
Old Apr 14, 2004 | 05:58 PM
bigpowerstroke
thanks, now I have an idea of what to do
