1978 - 1996 Big Bronco
Console
Old Apr 10, 2004 | 04:10 PM
BRONCO93EB's Avatar
BRONCO93EB
Question Console
You guys wont believe this. I just bought an overhead console auot-dimmer mirror, both lighted sunvisors and two leather padded door panels for $150.....good deal or what? They came from a '96 EB Bronco....right color and everything........only problem I cant seem to locate the outside temp sensor...and the wire harness was cut at the driverside door when someone took the door.......any ideas or help???? Oh I also got the wood trim inserts for the dash and the door panels thrown in from a F150 EB.......Thanks
Old Apr 10, 2004 | 09:21 PM
broncobillybob's Avatar
broncobillybob
Sweet deal, especially with the freebies. As for the wire harness all you should have to figure out is what wire is what and hook up another wire harness to it or hook the wires together straight up. Obviously you are putting the overhead console in your truck, its been discussed on here before. Just do a serch in this forum if you need any help with it. If it didn't come with a temp sensor, you'll have to 'procur' one from the junkyard.
-Triple B
Old Apr 10, 2004 | 11:34 PM
Trucky18's Avatar
Trucky18
F87Z-12A647-AA, PN for the temp sender via ford I did a write up on installing an Explorer overhead console, its on my superford
Old Apr 11, 2004 | 12:18 PM
screwy's Avatar
screwy
The sensor is behind the grill.
Old Apr 11, 2004 | 03:06 PM
BRONCO93EB's Avatar
BRONCO93EB
I guess thats why I couldnt find the sensor...the frontend was gone on the bronco I took it from......thx
