where do I find the keyless entry code for 01 excursion
Old Apr 3, 2004 | 08:41 PM
logginhard's Avatar
logginhard
just bought a 2001 ford excursion but dont have the keyless entry code can anyone help
Old Apr 3, 2004 | 08:48 PM
lockdoc600's Avatar
lockdoc600
the original selling dealer may be your best bet. The code originally came written or typed on the back of the Emergency Road Service wallet card. I'm not sure if Ford Motor keeps this info or not but the original dealer would have it on file.
I hope this helps.
Old Apr 3, 2004 | 08:52 PM
logginhard's Avatar
logginhard
I have been told I can find it under dash somewhere but I have been unable to locate it.
Old Apr 3, 2004 | 09:30 PM
photomanz's Avatar
photomanz
Logginhard,
I just had this same issue. It wasn't written down anywhere, so I had to go to the dealer and they hooked it up to the computer and retreived the code. They charged about $40. Alan
Old Apr 3, 2004 | 09:34 PM
logginhard's Avatar
logginhard
Looks like it is probably going to end up costin me some doe.
Old Apr 4, 2004 | 09:14 AM
thegrizz's Avatar
thegrizz
keyless entry
there is a module behind the left 1/4 trim panel that has the code on it,
i dont recommend removal unless you are truly experienced,the trim
is hard to remove and can easily be damaged which will turn into an
expensive replacement.your dealer can retrieve for 0.5 labor hours,
worth it!
Old Apr 4, 2004 | 10:04 AM
rozett's Avatar
rozett
I participate in four different truck forums for the Excursion and I have seen this question come up a dozen times a year for several years. I have NEVER heard of one single person that has actually found the code written anywhere under the dash. Just bite the bullet and pay the dealer to fetch the code from the computer. Unless you bought it from a dealer, in which case you can shame them into giving it to you for free... like I did.
Old Apr 4, 2004 | 11:19 AM
thegrizz's Avatar
thegrizz
behind the 1/4 trim panel certainly isnt under the dash!!!!(left 1/4 trim that is)
Old Apr 5, 2004 | 08:56 PM
Toyman's Avatar
Toyman
I worked in a Ford garage as a tech when the X came out and the Ford manuals say that it is located on the module, which supposed to be located behind the trim on the left side of the vehicle. It was much easier to pull the number on the computer. If you have not had the computer updated it would be my advise for you to have them do any updateds and have them tell you code at the same time. Killing two bird with one stone. If your X is under warranty the updates should be free and they will just tell you the code. Toyman
Old Apr 6, 2004 | 10:38 PM
rdc767's Avatar
rdc767
I bought my x a few weeks ago. I have the code. But the doors don't unlock when I push the code in. Is there a trick? 5 digits I believe. I don't have the owners manual. Its on order.
Ron
Old Apr 20, 2004 | 07:08 PM
Bill4Kath's Avatar
Bill4Kath
I couldn't find the code at all on my 02 X. My 99 Explorer did have the code on the box, which was located inside of the left rear quarter panel.
Old Apr 20, 2004 | 07:56 PM
HomerWinzlow's Avatar
HomerWinzlow
Ron
You may have a defective keypad, a common occurance. The keys may light up but one may not function. So if you hit say 14645 it may only see you punching in 165... because the 4 key is bad. This can be tested using a PID monitor on the NGS scanner at the FORD dealer. PID KEYPAD will tell the NGS what key was pushed as your run through the keys. Replacement of the keypad would be necessary to fix it.
On 2001 Excursion the Keyless Entry is controller by the Gem Module and keycodes are retrieved from the Gem.
Principles of Operation
The remote keyless entry system is controlled by the generic electronic module (GEM). The switches are wired directly to the lock/unlock relays and the GEM is wired to the relays in parallel. Pressing a switch to lock or unlock grounds the appropriate lock/unlock coil closing the relay and supplying voltage to the actuator to lock/unlock the doors.
Entering the keypad button sends a ground signal to the GEM. When the code is entered in the correct order the GEM grounds the driver unlock relay coil closing the relay and supplying voltage to the driver door actuator unlocking the driver door only. Pressing 3/4 within 5 seconds of factory code sends another ground signal to the GEM causing the GEM to ground the all door unlock relay coil supplying voltage to the passenger door lock actuators unlocking the passenger doors. Pressing 7/8 9/0 buttons together at any time sends a ground signal to the GEM causing the GEM to ground the all door lock relay coil supplying voltage to all the door lock actuators causing them to lock.
The transmitter sends a signal to the GEM causing the GEM to unlock the driver or passenger doors depending on the button pressed.
When the GEM receives the correct signal from either the keyless entry keypad or the remote transmitter the GEM will then command the interior courtesy lamps and the keypad illumination on.
When the panic function is activated from the remote transmitter, the GEM intermittently grounds the parklamp flash relay and the horn relay coils closing the relays and supplying voltage to both the parking lamps and the horn.
The remote transmitters and the remote keyless entry use a rolling code to prevent the transmitter identification code (TIC) code from being "captured" by a code grabber. The system rolls the counter in the transmitter and in the remote keyless entry every time a remote transmitter button is pressed. If the remote transmitter is pressed a large number of times outside the range of the vehicle, the rolling codes will fail to synchronize and the vehicle will stop responding to that remote transmitter. At this point the transmitter needs to be reprogrammed to the system.
On 2002 and later Excursion the Keyless Enty is controlled via the VSM, vehicle security module, mounted under the center or the dash.
Old May 14, 2004 | 12:50 PM
Scurv's Avatar
Scurv
left 1/4 trim panel??? They told me yesterday that it is on the module located inside the drivers side door panel???
Old May 15, 2004 | 08:13 PM
rlh68050's Avatar
rlh68050
Just go the the dealer and have them pull the code with a scan tool. Hell, I have my own NGS and if you were anywere near me I would do it for free. It's that easy.
Old May 15, 2004 | 08:46 PM
Canuk's Avatar
Canuk
My 2K Expedition had the code under the dash on a box near the emergency brake. If you lay on your back with a light you will see it tucked up high in there on the exterior side. If the X is the same as the Expy.
