Tranny Fluid
Originally Posted by Gary E K
Did you drain the converter?
Originally Posted by T- Squared
Yea I did. Pulled the pan and replaced the filter at the same time. I got to the t/c plug by watching thru the hole in the housing while bumping over the engine with the starter. Took a few tries but it finally lined up!! It takes a while for the fluid to drain out of there....
Gary E K, if you go to https://www.ford-trucks.com/lc/lc.ph...hangingatf.php
this should answer any questions you should have.
I just used this info to change my atf and all went well.
