check engine light (HELP)
Old Mar 27, 2004 | 02:14 PM
s_roberto69's Avatar
s_roberto69
Question check engine light (HELP)
Hello, i currently installed a flowmaster exhaust system and a different intake on my 2003 5.4 f-150, after a couple weeks my check engine light came on, i had a diagnostic test done and it came up dealing with fuel air mixture, im not exactly sure which way it was but i think the guy told me it was running with too much air, i disconnected my battery and cleared it out, it stayed off for about 3 weeks then came back on, does anyone know how to fix this problem, i dont want to end up screwing up my truck, by the way i am changing the intake to another one, i think im going to go with FIPK, air force, or a voolant, any suggestions there? someone told me i could buy a hypertech programer to fix this, is this true? please help and any information would be greatly appreciated, thanks.
Old Mar 27, 2004 | 09:04 PM
F2504x4's Avatar
F2504x4
HI and Welcome to FTE.
what codes came up?
Old Mar 27, 2004 | 10:09 PM
ritchie46's Avatar
ritchie46
First thing I would do is to clean the mass air sensor with some electrical parts cleaner, just spray it in. If your motor is running lean in both bank 1 and 2 it is frequently caused from the MAF being dirty or bad.
Old Mar 28, 2004 | 07:10 PM
s_roberto69
i forget which codes came up, i will try cleaning my MAF tomorrow and see what happens.
Old Mar 28, 2004 | 07:53 PM
F2504x4's Avatar
F2504x4
just thought of this, check the pcv plastic hose where it runs into the back side of the engine. the rubber elbow can crack.
Old Mar 28, 2004 | 11:27 PM
LxMan1's Avatar
LxMan1
Yup, mine did that @ 30,000 miles. They sure don't make em' like they used too.
