1978 - 1996 Big Bronco
Starting problems
Old Mar 24, 2004 | 10:13 PM
pirocat29's Avatar
pirocat29
Starting problems
I bought my 1982 bronco when i got it didn't run. replaced the plugs, wires, cap, rotor, battery, coil, ignition module, ignition switch, starter, turnkey, solinoid, and steering colum. It would turn over great and would start using the key, After a couple of weeks it would stop starting just cranked. Replaced the switch and turnkey it starts now but the starter sticks as long as the motor is running i have no idea what it could be. hasn't been driven. (not road worthy now) please some insight would be greatful
Old Mar 24, 2004 | 10:25 PM
mustangman65_79's Avatar
mustangman65_79
make sure all the wires are connected on the right side of the coil, not the starter side, but the batt side.
Old Mar 24, 2004 | 10:34 PM
pirocat29's Avatar
pirocat29
now which side is the starter side. we had to remont the coil i wouldn't go back on the intake. And to the best of my knowing all of the wires are tight
Old Mar 25, 2004 | 02:03 PM
NotoriousM3's Avatar
NotoriousM3
the same thing happened to me every time i'd start the damn the the starter would stick... i tried replacing the solonoid many of time and it fixed it for a little while finally i got a heavy duty solonoid - high amp and it fixed the problem
Old Mar 25, 2004 | 04:29 PM
Kemicalburns's Avatar
Kemicalburns
also a sign of a bad starter. replace it and see if it still happens
Old Mar 26, 2004 | 07:12 AM
pirocat29's Avatar
pirocat29
its a brand new starter. Thanks i am going to try that high amp solinoid.
Old Mar 26, 2004 | 12:04 PM
NotoriousM3
let me know if it works
Old Mar 26, 2004 | 07:39 PM
pirocat29's Avatar
pirocat29
I went to my local auto parts store (they know me by name thats how much im in there) and they said that it sounded like my solinoid but my starter teeth were all chewed up so im not going to know what it is gonna try the starter first but will let you know.
Old Mar 27, 2004 | 09:29 PM
pirocat29's Avatar
pirocat29
Ok i replaced the started still stuck open. Replaced the solinoid with a heavy duty solinoid. When connected it turns over with out the key. Second the negitive cable gets hot and sparkes i am at a loss with this one
Old Mar 27, 2004 | 09:48 PM
Jdenninger's Avatar
Jdenninger
sounds like a bad solenoid.
Old Mar 27, 2004 | 10:00 PM
pirocat29's Avatar
pirocat29
its brand new. along with the whole igniton system.
Old Mar 27, 2004 | 10:12 PM
Jdenninger's Avatar
Jdenninger
i had bought a new soleniod for my bronco and after i installed it and reconnected the batt it was turning over without the key. It was a bad soleniod from the autoparts store. if you take a meter and test for continuity acroos the solenoid you should have an open circuit. mine tested closed. NFG. went and got another one. Problem solved.
Old Mar 28, 2004 | 01:23 PM
pirocat29's Avatar
pirocat29
thanks ill try that
