Adding an Overdrive?
Old Mar 23, 2004 | 02:55 PM
Levergun's Avatar
Levergun
Question Adding an Overdrive?
Does anyone have any info on adding an over drive to a NP435?
Old Mar 23, 2004 | 06:38 PM
78fordman's Avatar
78fordman
Over/underdrive unit. You really shouldn't add a gear in there, would not be worth it. A over/underdrive unit or a ZF tranny would suit you perfect.
Old Mar 24, 2004 | 12:21 AM
Levergun's Avatar
Levergun
What do you mean? Can you elaborate a bit?
I found a neat O/U drive unit today from Gear Vendors. Will bolt right up to my NP435. All I have to do is shorten my divorce mount drive shaft. But the kicker is this......only 20% reduction in RPM. That means I go from 3000rpm to 2400rpm. At this point it is not worth it at $2700 for the unit!
It may be better to put a nice Automatic in it with a B&M shift kit. Or somthing of the sort......
Your thoughts?
Old Mar 24, 2004 | 07:26 PM
78fordman's Avatar
78fordman
well, the cheapest and easiest would be an AOD, there a re companies which build bulletproof AOD's, someone will chime in and help me out with a name. The gear venders unit was what i was talking about. 20 percent reduction is pretty good, there is only a 29 percent drop from o/d in a E4OD, and i think they are the highest.
BubbaC
6.2L V8
Jul 4, 2013 05:55 AM
BrentKasson
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 9, 2004 09:38 AM
PSD_Power
Jan 13, 2003 10:52 AM
otto
Feb 4, 2002 06:24 PM
alanscott
Site Announcements
Jan 27, 2001 10:41 PM
