Yet Another 2.9 Problem ! ! !
Old Mar 14, 2004 | 08:40 PM
geowolf's Avatar
geowolf
Lightbulb Yet Another 2.9 Problem ! ! !
Ok get this.... I installed a new 2.9l in my truck. from an 88 to a 91 with the 91 ECU( if it even matters ) and after replacing TUNS of parts; plugs / wires / cap / button / ignition coil / fuel pressure regulator and setting the timing.... it runs like crap !!!!
in fact, nothing I have done so far has changed anything. Today I started pulling wires with it running. the no. 3 and 6 cylanders arent doing anything. they get plenty of spark and fuel and have tuns of compression (like 165 - 175 psi) so.... I looked at the no.6 plug and it has antifreez on it.
OMG I am thinking head gaskit!. but.... plenty of compression and no belching into the radiator. so I am thinking intake gaskit right??
However.... I sprayed carb cleaner all around the intake and no change in idle.... any thoughts on what I should do next??
first lets get the first thing that comes to mind.... the firing order 1-4-2-5-3-6 and yet they are in the correct order...
Any thoughts ? ? ? ? ??????
Old Mar 19, 2004 | 09:25 AM
8588ranger's Avatar
8588ranger
Did you remove the spout connecter before you setted the timing?
Old Mar 19, 2004 | 10:44 AM
mrshorty's Avatar
mrshorty
2 thoughts:
1) Does an intake manifold gasket leak have to be evident from the outside? Could it only be leaking through an internal seal (between a coolant passage and an intake passage), but the outside edge of the gasket be sealing fine?
2) Are the 3 & 6 injectors "firing" or are they stuck open continuously feeding fuel into the cylinders?
Old Mar 19, 2004 | 08:04 PM
geowolf's Avatar
geowolf
stuck open continuously feeding fuel into the cylinders is my thought. gonna pull em next
Old Mar 19, 2004 | 10:22 PM
mrshorty's Avatar
mrshorty
You might try a fuel pressure test before going to the trouble of pulling the ionjectors out. Hook up a fuel pressure gauge and pressurize the rail with the fuel pump. If the fuel rail doesn't hold pressure when the pump(s) shut(s) off, then one or more injectors might be stuck open amongst other possible causes of the pressure bleeding off).
77mud
Apr 21, 2013 01:40 PM
bondob
Nov 20, 2009 08:24 AM
ford784x4
1983 - 2012 Ranger & B-Series
May 22, 2007 09:03 PM
geowolf
Mar 15, 2004 07:38 PM
