Dual alternator install - successful!
Old 07-16-2010, 12:25 PM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
Well Thanks for finding this old thread either way! I have searched in the past for info on this now I can save this very useful thread.
Perhaps we can talk Jim into a sticky for VERY useful threads. Like this one and maybe my window motor thread and a ton other that I can think of...
Old 07-16-2010, 12:41 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Nolan,
I found this old thread useful in the fact I have been wanting to mount a clutch activated compressor where the second alternator would go.
I'm going to copy and paste post #1 to a word document or a PDF or both. If you want a copy let me know.
Old 07-16-2010, 02:23 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
A clutch operated compressor would be a good addition.In days of old we use to mount York or Tecumseh a/c compressors but I don't see enough room on a PSD
Old 07-16-2010, 02:57 PM
PaysonPSD's Avatar
PaysonPSD
Ray,
I've heard of those Yorks.
It would have to be no larger then an alt. Maybe a small A/C compressor with a manually operated clutch. I'm not looking to run air tools but just air up tires. The snag would be lubrication for the A/C compressor without the lubricant getting in the output air flow. Is there a feasible way of doing this?
Old 07-16-2010, 03:01 PM
rbaker6336's Avatar
rbaker6336
I don't know of any way to run the modern a/c compressors since the lube oil runs through the system.The old compressors had a crankcase for oil
Pretty much need some type of oilless compressor
Old 07-16-2010, 06:18 PM
4inchlovin's Avatar
4inchlovin
Robin are you thinking for on-board air? If so count me in!
Old 07-16-2010, 06:30 PM
PaysonPSD's Avatar
PaysonPSD
That's what I figured would be the hurdle using an A/C compressor.
If I figure something out you're in Nolan. Gonna be a fall project though.
I should start a separate thread. I'm sure someone has done this already.
Old 07-16-2010, 06:32 PM
djanzen's Avatar
djanzen
djanzen is offline
On-Board Air - York Oil System Modification
Read the jedis york compressor mod.
I am going to put this on my 6.0 there is enough room there after moving some stuff. 7.3 should be no problem.
Old 07-16-2010, 07:18 PM
PaysonPSD's Avatar
PaysonPSD
Dean,
That's a damn good write-up you found. Thanks for the link. Reps to you.
When your done with your's let us know over here in 7.3 land how it all went. Or at least post the link to your own write-up in 6.0 land.
Old 09-18-2010, 06:24 AM
JonathanN's Avatar
JonathanN
JonathanN is offline
Quick note on that hose... that's what was in my truck already, but I don't have the 2nd alternator. But anyways, make sure you have a zip tie holding the hose to the block like Payson did in his picture. Mine didn't for some reason and when I was working on the truck one evening, I shoved the hose out of that crotch and got it wedged between the belt and the block. I didn't know I had knocked it outta whack until I had burned a hole through the hose with the belt. I'm interested in mounting a York to the alternator bracket... that's how I found the thread. Any more links/info would be appreciated!
Old 09-18-2010, 12:18 PM
bigbubba87's Avatar
bigbubba87
bigbubba87 is offline
could you post a pic of the dual set up.
Old 12-04-2010, 12:53 AM
hotweekend's Avatar
hotweekend
hotweekend is offline
do u know if Napa or AZ sell that hose? I am searching on line and i can't find it.
TYhank's in advance!
  #28
Old 12-04-2010, 01:04 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Hose - Radiator Upper
Product Line: NAPA Belts & Hoses
Part Number: NBH 9066
Should set you back about $15.
  #29
Old 12-04-2010, 01:15 AM
hotweekend's Avatar
hotweekend
got it in Napa ! hose part NBH 9066
here is the link ...
Store Locator | NAPA Online
  #30
Old 12-04-2010, 01:18 AM
twags6's Avatar
twags6
twags6 is offline
Hey guys, why not move the alt to the lower location and use the upper spot for the compressor?
Quick Reply: Dual alternator install - successful!
